It is currently Wed Aug 20, 2025 8:22 am
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2
 Post subject: Re: wood vs celluoid
PostPosted: Wed May 14, 2014 5:39 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
how do you finish celluloid??? ,sand and pore fill with z poxy as normal??
MK5acoustics.com
PostPosted: Wed May 14, 2014 7:53 pm
City: Tyler
No , I just shoot finish on it.
PostPosted: Wed May 14, 2014 10:58 pm
I've noticed a discernible difference in the tap tone of a sound box when routed out for bindings. It goes from a vibrant beautiful sustaining tone to a dull thud. I can't imagine wrapping that in plastic and hope to get it back.
Flame away but I had these words written on my first web site circa.. oh when ever the web came out. hahahha
I will say no more for now :)
PostPosted: Thu May 15, 2014 2:27 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
kencierp wrote:
Regarding Ebony binding -- I've only used it on few Classical builds. I agree its a PIA to bend, what I finally ended up doing was laminating .028" Ebony veneer three layers, once in place it looks like a solid binding -- just a thought.
In general, can one use veneers to build up any purfling and it look right?
Edit: I meant binding
PostPosted: Thu May 15, 2014 4:13 pm
I've only used veneers for Ebony the glue line is invisible with such dark wood. I have heard of guys using veneer strips for Bloodwood (it can be a PIA as well) and Mahogany but I did not see those instruments.
Regarding hearing some difference celluloid vs wood bound guitar -- maybe a space being of some sort could -- a human earthling I think not. $.02 -- Brain Burns however, has an article regarding and describing the quantum improvement resulting from binding an instrument originally constructed with no binding. I'll try and find it -- the story was compelling.
Ken Cierp
PostPosted: Thu May 15, 2014 4:37 pm
First name: tim
Last Name: minkkinen
City: charlotte
State: nC
Zip/Postal Code: 28203
Country: united States
In my experience building a guitar with solid versus kerfed linings you will not hear a tap difference on the box after cutting the ledges. I think it's an air thing. Maybe. Possible?
Tim
PostPosted: Thu May 15, 2014 4:54 pm
Very definitely an "air thing". Until the binding is applied and dry, there is air leakage and that inhibits the box from functioning correctly.
PostPosted: Thu May 15, 2014 6:16 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
I don't think its an air thing, hopefully Trevor will weigh in and do some "splainin", solid linings on the top help to improve the responsiveness by reducing energy loss to the sides...helping the sound waves get reflected back across the soundboard..
MK5acoustics.com
PostPosted: Fri May 16, 2014 7:36 am
Gee, that's odd...
I can hear the difference in tap after I rout bindings in a guitar with kerfed linings. The box leaks like a sieve and it doesn't pump through the soundhole. After the binding is applied, it pumps again...
PostPosted: Fri May 16, 2014 7:47 am
Perhaps one of you guys should start a new thread -- getting way off topic.
Ken Cierp
PostPosted: Fri May 16, 2014 8:47 am
Haans wrote:
Gee, that's odd...
Yeah no doubt about it. Hey... Sound ports anyone?
PostPosted: Fri May 16, 2014 8:53 am
Soundports?
No thank you...
PostPosted: Fri May 16, 2014 10:54 am
Use kerfed linings, rout the box and leave the bindings off - micro sound ports, the latest Feature! laughing6-hehe
Hi Mike,
I glue veneers together in the same order they were sliced, and the darker woods often appear to be "solid" even when looked at on edge. Lighter colored woods often show the glue line.
PostPosted: Fri May 16, 2014 11:17 am
That statement has virtually no basis in reality... I understand the emotion of it, but the reality of it is there's no hard evidence to support that.
Out of curiosity, what are you using for a finish? If you say any form of poly, and not nitro, shellac, or (oil) varnish, you just contradicted yourself...
beehive
:D
PostPosted: Fri May 16, 2014 5:06 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Nick Royle wrote:
Anyone want to defend ebony binding? I tried bending ebony and cracked it all. The black ABS I used instead looks really good.
I need black binding again soon and I'm trying to convince myself that I'm not cheapening the guitar at all by using ABS over ebony! :lol:
I don't have any problems with ebony. Actually, it is one of the easier woods to bend for me. It doesn't kink and there is very little spring back. I bend by hand on a hot pipe. I soak the binding for a few hours in the bath tub with fabric softner, then bend with the hot pipe cranked up to 400-425 degrees (tested with a laser temp gun). When the wood dries out I re-wet with a water/fabric softener solution.
For me it depends on the finish I will use. As others have stated, ebony looks just like black plastic under a film finish like lacquer. So for a lacquer finish I would just use black celluloid instead of ebony. But if I'm doing a wiping varnish finish I would use all wood, and wouldn't use any plastic or celluloid on the instrument at all, because that finish lends itself to a natural "in the wood" satin look.
Has anyone ever used holly for binding? That might be a good wood alternative for white plastic.
PostPosted: Fri May 16, 2014 9:29 pm
beehive
:D
Hahahaha I am almost only FP now. Bug poop, eggs, n' licker.
But I do agree with your statement 100%! And if you were to finish my original quote then you would note that I said that this was something I wrote on my website almost before websites were even known to the common man (or woman). I only had ten guitars under my belt and thought I knew what I was doing... I didn't.
I still don't :)
PostPosted: Sat May 17, 2014 8:30 am
Same here. The more I know, the more I know that I don't know anywhere near enough.
[:Y:]
Edit: Man I wish I could learn to French Polish..... I suck at it.
PostPosted: Sat May 17, 2014 8:52 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I only have 7 under my belt - all classicals (or at least that's what I call them) and all with wood bindings. Have never tried celluoid, but am gearing up to try steel strings, and I do believe I would try celluloid if I were trying to emulate a vintage guitar. I also suck at French polish, but I'll keep trying (at least on the tops).
PostPosted: Mon May 19, 2014 7:53 pm
Last Name: Beaver
City: Lake Forest
Wood is King
Joe Beaver
Maker of Sawdust
PostPosted: Wed May 21, 2014 12:41 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Purely a design choice for me. A clean job looks great in either wood or plastic. I'd only use grained ivoroid, tortoise shell, or black for the plastics though. I think solid white or cream looks unnatural.
Users browsing this forum: Ken Lewis, Robbie_McD and 8 guests
